Old 10-10-2012, 10:37 PM
Joey Jarrard's Avatar
Joey Jarrard Joey Jarrard is offline
Administrator
Default CAMaster Cobra 508 with ATC and Agg Head
Here are a few pics of a new machine just set up today in Chatanooga, TN
It has a 13 HP HSK spindle with C axis and a aggregate head for horizontal work. The customer builds patterns for very large pumps and valves for the foundry industry.
Machine is a CR-508 with a 13 HP HSK spindle. 10 tool positions with aggregate head.
16" Gantry Height, 25 HP Dual Stage Vac Pump. Customer has Aspire and Cut 3D
Joey Jarrard
US Router Tools
888-720-TOOL (8665)
www.usroutertools.com
Old 10-11-2012, 01:08 AM
Mick Martin's Avatar
Mick Martin Mick Martin is offline
CAMaster Cobra Owner (MOD, KOTR)
Nice looking machine joey, I don't understand ... what is an aggregate head ... I did find this via Google http://www.woodworkingnetwork.com/ar...127749403.html
Mick Martin
mickmartin3@comcast.net
CAMaster Cobra 508 ATC + Recoil + Popup Pins
Digitize Touch Probe
Wincnc Handheld Serial Keypad + Wireless Pendant
Hurricane vacuum
WinCNC + Aspire 9.5 + PhotoVCarve + EnRoute 5
www.customarchitecturalsignage.com
www.mickmartinwoodworking.com/
The search function on the forum is your best friend!
Old 10-11-2012, 08:51 AM
Will WinCNC run the C-axis? I imagine programming for that aggregate head will be a little complex, since the working radius would change depending on the length of the tool you use in it. . .
Intriguing though. I can think of lots of uses for that!!
Old 10-11-2012, 09:26 AM
Administrator
WinCNC is a 6 axis controller and has no Issue with the movement of this feature. You are correct that the programming is the trick. You will need MaterCAM or Rhino to pull this off.
Joey Jarrard
US Router Tools
888-720-TOOL (8665)
Old 10-11-2012, 09:49 AM
Clark Goad Clark Goad is offline
Have you worked through the MasterCAM PP yet? A video of your aggregate in action would be awesome.
Old 10-11-2012, 06:08 PM
Administrator
We have a basic one. Each one has to have it tweaked a bit.
Not an issue Brandon has been trained on MasterCAM I am sure he can help if need be.
Joey Jarrard
US Router Tools
888-720-TOOL (8665)
Old 10-12-2020, 06:56 AM
antnee antnee is offline
Joey are they're any videos of this modern marvel in action?
Old 10-12-2020, 10:08 AM
Jim Becker Jim Becker is online now
That "modern marvel" is a 2012 model, antnee...this is a very old thread. You may want to contact Camaster to see what videos they may have posted for the current Cobra design which is even beefier than what's in Joey's original posting.
