Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > New Forum Members
Old 02-29-2020, 08:24 AM
Memory cap on turn on Switch,, If I rememeber correctly a "Mini" Cobra was smaller machines 4 x 4, 3 x 6 and various sizes built before the add of the Stinger
I have a good friend who had a custom build of 3 x 6
there were a few and I mean a few original sitngers which are not like the ones you know today as the table tops, they had bases and ran on Mach three, I think there were only three of those machines. sen me a photo and i will tell you what I know.
Old 02-29-2020, 09:07 AM
Ron Bontz Ron Bontz is offline
https://lexington.craigslist.org/bfs...071758342.html
Old 02-29-2020, 09:09 AM
That is a real Mini Cobra,, heavy full base and Wincnc (Check that)
Built on the same total specs as the big brother. Heck of a good machine
Old 02-29-2020, 09:12 AM
I see it has Mach 3 but do not let that stop you, Mach 3 is a capable controller.
it also has the 3.25 porter cable router, workhorse of a router and easily repairable ,, i have 5 of them and all we ever fixed were brushes, som are 10 + years old
Old 02-29-2020, 09:34 AM
That's a darn sturdy looking machine!
Most likely could also be converted to a more current controller if one desired....Gary Campbell would be a good resource to talk to about that. Centroid or WinCNC or "worst case", Mach-4.
Old 02-29-2020, 03:27 PM
Thank you.
I am familiar with the router. I've been using a couple of them for a good 20 years in my router tables. Just a thought as this one would require a lot of upgrading.
Old 03-30-2020, 11:39 PM
Joey Jarrard's Avatar
Joey Jarrard Joey Jarrard is offline
Administrator
Originally Posted by Ron Bontz View Post
Logan, Thank you.
There appears to be someone with a SR23 in Mooresville IN 46158 ,but I have not been able to figure out how to contact. Nothing pops up in the search.
Contact the sales team they can privately ask the customer if they won’t mind giving you a call.
Most like to talk shop.
Joey
Joey Jarrard
US Router Tools
888-720-TOOL (8665)
www.usroutertools.com
