Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Software > Cabinet Parts Pro
Old 01-22-2019, 10:20 PM
mike75bugl. mike75bugl. is offline
Default Can't get shelf dado's correct
I am trying to build my first cabinet with CPP. It is a full base cabinet that is 79.5" tall. I would like to have two shelves fixed that are set into dados to hold the cabinet together and then shelf pin holes between the shelves for movable shelves.
I can't seem to get the setting right to do this though. It either has no dados or too many dados (dadoing for the movable shelves also).
Am I missing something simple here?
Mike
Old 01-22-2019, 11:12 PM
Haven't used it, but here.
https://www.youtube.com/results?sear...+pro+tutorials
Old 01-23-2019, 06:05 AM
Make sure you have done setup correctly and chosen each feature per cabinet, We use this daily for a good ten years
http://www.cabinetpartspro.com/Support.aspx
cpp, dado, shelf
