Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > CAMheads Show Room
Old 02-02-2016, 10:36 PM
Default Sons of Anarchy 3D
Did this one out of yellowheart, pretty large at 16x11". Thick too, 1.25".
Took some time, about 5 hours with a 1 hour roughing pass, carved this pretty deep into the block. Also have about 1 hr hand sanding it. Only finish I used is matte clear coat.
Yellowheart is a cool wood, a little plain looking at first glance, but if you catch the right lighting almost has a brushed metal look. Machines nicely, also very dense and solid.
Old 02-03-2016, 01:17 AM
Can practically see the Men of Mayhem sitting around the table. Pretty cool.
Mike Davison www.DavisonWoodworks.com
Stinger II with Recoil, GCNC Sidewinder Lathe, Aspire, Sketchup
Old 02-03-2016, 02:30 AM
Shhh don't tell Jax I made it !
Old 02-03-2016, 10:24 AM
aogtrs aogtrs is offline
Super cool! I've had my plans to make one of those myself.
Nice work--that looks super clean.
Andrew Olson
AO Guitars
www.aoguitars.com
Stinger I FTC
3.25 HP Porter Cable & Counter Balance
Kent Dust Shoe
Rhino 3D
RhinoCAM
Old 02-03-2016, 07:47 PM
Is nice and clean but took some effort to get it that way.
I did a profile pass down to .7 around the entire perimeter to clean up the edges, then spent an hour or so hand sanding to get it close to perfection. Also used a dremel with a little deburring bit to clean up the many nooks and crannies in this design.
Old 02-04-2016, 09:57 PM
sheustess sheustess is offline
That looks great did you create the 3-D yourself or did you have someone do it for you
Seth Heustess
Hcrafters LLC
Stinger Stand
3 1/2 Porter Cable Router
Vac Top/Black Box Storm Pump
Dust Collection
Vcarve Pro 8/Win CNC
Drop Cam
Old 02-04-2016, 10:27 PM
Paid file, I forgot where I got it from.
I can produce a rendering like that only in my dreams, but I sure can carve them !
Old 03-25-2016, 05:38 PM
Another one is wlanut, this one with a textured background
Old 03-25-2016, 06:48 PM
Looking mighty fine!!
WinCNC 2.5.03, Aspire, PhotoVCarve, Windows 7 Pro SP1
Old 03-25-2016, 11:40 PM
Thanks man, I did another one today, I'm on a roll with the textures. After 4 years of CNC this is the 1st time I have done textures, not sure why, But I'm like a kid with a new toy now.
This purpleheart was well on its way to being a top 10 masterpiece for me, but I had an incident during roughing that nearly ruined it. The bit slipped out of the chuck, must have dragged around a bit before it came free. So it dug out some gouges that were below the finishing pass.
Didn't know it at the time, I restarted the roughing, then did the finish. Took about 3 hours, when I cleaned off the dust I noticed the gouges. At first I was ready to toss it in the scrap pile, but especially with the textured background, it really doesn't look to bad with the gouges.
There are at least 3, 1 on the bottom of the globe, one on the head and the most noticeable one to me, right top side of the hat.
Bit felt weird when I was tightening it, I should have taken notice. I removed the collet [after the damage was done] and it was clogged up with dust so I gave it a good wipedown with tool solvent, hopefully am good to go now.
