![]() Quote:
Vcarve is easy to use and does a good job on the CAM side, but God help you if anything needs to be drawn or edited in CAD. The word archaic is a an understatement. Every time I use it I get flashbacks from high school drafting class using AutoCAD 11 and Windows 3.11.
Stinger 3, 3kw, 15hp FPZ blower |
What happened to the T-Square and combination ruler?
![]() Maybe that is why Vectric CAD seems easy? It's your frame of reference!
Charlie L Stinger II, 48 by 48, 1.7 kW Spindle, FTC + Laser + Recoil + Vacuum, July 2012 WinCNC 2.5.03, Aspire 9, PhotoVCarve, Windows 7 Pro SP1 |
Posting an update here as I've finally tracked down a bug in the drilling code which had caused many broken bits and ruined workpieces.
Prior versions were not always retracting out of the workpiece when moving between holes... obviously, not an ideal toolpath. Turns out this was due to a questionable set of assumptions that Autodesk used in the stock post processor that became outright wrong whenever you were drilling a hole that started below the top of the workpiece. Anyway, this is now fixed (it now retracts to what you set as the retract height in the drill operation Heights tab) for the "Drilling - Rapid Out" cycle ONLY. I have not spent any time with the other drilling cycle types to know their peculiarities. |
Slept on it and realized there was no scenario in which I wanted to keep the old drilling retract behavior in the other drilling cycle types, so went through and updated all of the other drilling profiles to have the correct / safe retract plane. Deep drilling / counterboring / etc. should all now work safely vs. the Autodesk stock post.
I didn't look at the files but it is certainly nice that you are sharing your work. I might need it someday? Or others.
I wonder if this is something you'd want to be sure that CAMaster sees in case they want the Fusion 360 PP updated?
All to often New CNC Owners think a PP is a responsibility of the machine company,, The actual answer is the Software company bears this responsibility as without a cohesive operation they could not sell software to the masses with hundreds of different machines and control systems
Wincnc has always been a very stable Providor and does not beta teast on the end user, as well the software is Very friendly to software companies
James McGrew CAMaster ATC 508 The principle of Measure twice cut once has not been replaced by a CNC www.mcgrewwoodwork.com https://www.facebook.com/pg/Mcgrew-W...=page_internal Camera 1 ATC Closeup ! https://video.nest.com/live/esNTrZ fixed 4-27-2020 |
Thread Tools | |
Display Modes | |
