Old 04-04-2018, 02:50 PM
Brian O Brian O is offline
Default rename layers
I am have problems renaming layer. I used to be able to double click the name and type in a new one. I right click the layer where it says rename,it turns blue just as if you click it. I type in new name hit enter but the old name is still there. I even opened a new layer to give it the new name I want but it just puts in a layer number. I recently updated to the version 9 of vcarve and never had this issue in 8.5. What am I missing here?
Brian O
stinger III x3
vcarve pro
Old 04-04-2018, 03:08 PM
It's working properly on my copy...did you try restarting the application? Restarting Windoz?
Old 04-04-2018, 03:09 PM
Double clicking or bringing the drop down menu up both work for me on 9.
So it's not the version.
Old 04-04-2018, 03:26 PM
Make sure the new name is not already in use?
Old 04-04-2018, 03:40 PM
(Make sure the new name is not already in use?) BINGO!
It's always the simple things when I have alot going on in the drawing. In this case re drawing.
Thanks Ger
Brian O
stinger III x3
vcarve pro
