Old 09-14-2018, 05:05 PM
Brian O Brian O is offline
Default missing parts in nest
I have some cabinet parts I need to cut. I usually nest them by hand. Today I am using the nest feature. Problem here is I am loosing parts. Before nest I have 45 parts after nest I get 43 parts. I've tried it three times counting parts both ways. I always get the same quantity of sheets (5) as well. I have also numbered and grouped the parts so the number would stay with the parts. I keep missing parts 14 & 15. Anybody have this problem?
Brian O
stinger III x3
vcarve pro
Old 09-14-2018, 05:34 PM
I see 14 and 15 on sheet 1 when I nest that. the numbers are messed up looking
Old 09-14-2018, 06:52 PM
I actually remade your two missing parts and they are still tiny down in the corner of sheet 1.
They aren't missing, they are just tiny or the other parts are way to big. Which might be huge for all I know. What size is this cabinet?
I might not be smart enough to help you.
Old 09-14-2018, 08:49 PM
1601chief 1601chief is offline
I looked and 14 & 15 are open vectors I haven't found where the little parts belong but would suspect they were not joined to a part.
Andrew Pierce
Aspire 9.5
Wincnc
2 1/4 hp router
Performance Pkg Basic
Digitizing Probe
KRS Keypad
Old 09-14-2018, 10:42 PM
Yeah, that was it open vectors on 14 and 15.
Then part 29 needed the bottom dados grouped with the rest of the part. That's where those two small parts were coming from.
Here is your file back with those things fixed. Open vectors can drive you nuts.
