Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Tips & Techniques > CAMaster Cabinetmaking
Old 10-14-2019, 07:05 PM
Kozcnc Kozcnc is offline
Default shaker door Drill depths are different
hey guys I am having issues with my cnc drill different depths for my shaker doors. I am using mosaik to cut pocket style mdf doors.
I measure all my bits first and then I cut pocket with a 1/2 downshear and clean up the corners with a 1/8 downshear then hog out the center with a 1.25 bit. (i have the vortex set)
when I am done cutting the corners are about a 1/16 proud of where they should be be? is this normal is there a way I can cheat the depth on the bits to get it to cut the same depth like it should. Thanks
I would put a pic up here but i dont know how
Old 10-15-2019, 10:07 AM
Is your machine manual tool change or ATC? Do you have the Fast tool change?
If you're doing it manually, it's best to measure all the tools in the EXACT same spot. If you have the tool measure switch, sometimes tools will measure a few thousandths off from the next, but I've never had one 1/16 off.
It could be that your part is moving up or down a bit between the different tools. How are you holding down the part?
New all-steel 5X10 Panther
Pop up pins
VcarvePro 8 & 9.5
15Hp FPZ vacuum
Old 10-15-2019, 10:18 AM
Is the thin part that's getting pocketed maybe flexing up into the bit?
I might be picturing the wrong thing in my head?
Old 10-16-2019, 02:17 PM
Hi GuitarWes thanks for the response I have a Panther 408 with a ATC and the Drill bits are held in with the standard collets.
Old 10-16-2019, 02:20 PM
Hi the Real Jp I have the hurricane vac system and the spoilbaord is good, I am cutting with a down shear so I dont think its the bit.
Old 10-17-2019, 10:10 AM
Posting pictures from your computer: After saving your pictures to a folder on your computer, start a new post and scroll down to the Additional Options box. In the Attach Files section, click on the Manage Attachments bar. This will pull up a new window. Click on Choose File, click on the picture you want, and then hit the Open button at the bottom of the window. Repeat this if you want to post multiple pictures. When finished choosing pictures, click on Upload. Then click Submit Reply.
Pop up pins
VcarvePro 8 & 9.5
15Hp FPZ vacuum
Old 10-17-2019, 04:15 PM
Thanks Guitar wes here the pics of what shes doing
Old 10-17-2019, 05:37 PM
There's got to be something wrong with your cut depth settings in Mosaik for it to be that much out of whack.
Make sure you measure all tools. Did you replace an 1/8" tool and forget to measure it by chance? Just trying to exhaust all variables.
Pop up pins
VcarvePro 8 & 9.5
15Hp FPZ vacuum
