Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > CAMheads Show Room
Old 06-01-2020, 07:41 AM
very nice looking job!
Panther PT-404 (aluminum)
6 position ATC w/5hpHSD, Aspire 9.5/WinCNC, Recoil, Laser, Hurricane
near bottom of the learning curve!!
Old 06-11-2020, 10:00 PM
Mick Martin's Avatar
Mick Martin Mick Martin is offline
CAMaster Cobra Owner (MOD, KOTR)
Originally Posted by razor View Post
Received a request from a builder who had 300 yearish old house undergoing some renovations with a large addition. The dining room was 16x14 with 10' ceilings and customer wanted raised panel wainscoting. To do this in traditional frame and panel construction would have a small mortgage in itself. They opted to go with faux panels cut in MDF which reduced the costs tremendously. It was all CNC work and the panels were set up to go together like a puzzle. Installation for the trim carpenters was a breeze. I think I made some new friends/customers after this one....
GREAT work could you explain how you machined the panels, I have heard Jim stating it can be done using 3 router bits. How did you do these panels.
Mick Martin
mickmartin3@comcast.net
CAMaster Cobra 508 ATC + Recoil + Popup Pins
Digitize Touch Probe
Wincnc Handheld Serial Keypad + Wireless Pendant
Hurricane vacuum
WinCNC + Aspire 9.5 + PhotoVCarve + EnRoute 5
www.customarchitecturalsignage.com
www.mickmartinwoodworking.com/
The search function on the forum is your best friend!
Old 06-12-2020, 10:02 AM
He probably used something similar to these, https://www.toolstoday.com/v-13045-rc-2494.html.
You buy them in sets to produce different faux raised panels. There's a pdf in the description that lists the different panel looks and what bits to use together with the needed offset to achieve those looks.
Old 06-13-2020, 04:38 AM
razor razor is offline
Actually it was done using the moulding toolpath and a 1/8 bullnose bit. since the customer wanted a traditional bead style and rail look and standard raised panel, I didn't think it could be done with router bits. However because it was MDF I set the step over at .2 and it cut really fast....
Ray Melton
Montpelier Va
Panther 408
