Old 02-08-2019, 09:33 AM
Originally Posted by Guylaro View Post
Haha! I hadnít thought about having a wreck Joe! But ya youíve just scared me now so I will clamp a fairly large piece of ply or mdf to the phenolic top and then Iíll fasten my workpiece to it. Have you ever used double sided tape though to hold a workpiece? -Guy
I have used double sided tape...with mixed results. For "light work" like shallow v-carving I have not had any issues. But if you get too aggressive with speeds/feeds the tape will definitely let go. I now have a vacuum which I really like. When I get to small parts I will use the CA glue/tape trick. My double sided tape has been relegated back to just woodworking uses now.
Storm Vacuum
drummerjg@icloud.com
Old 02-09-2019, 12:08 AM
ScottM ScottM is offline
I have been using blue tape and super glue(2P10) for all my sheet aluminum cutting for aircraft panels.
I take a piece of MDF either 2x4 or 2x2 and use my vacuum table to hold it in place. Do a quick pass using the spoil board program to flatten it out, and the blue tape the area being cut on the board and then the sheet material.
Nothing has budged yet, other then the bits I snapped when feeding to hard. (sigh)
Camaster PT-408, 6-tool ATC, 5hp HSD, Servos, Hurricane
Old 02-11-2019, 08:34 AM
I saw a video on using normal tape as a hold down:
https://www.bing.com/videos/search?q...8A29&FORM=VIRE
Thought it looked like a really good technique, wouldn't work on my MDF spoil board at all, but would probably work on phenolic.
-PETE MALONE
SR-34
V-Carve Pro V8
Recoil Ready
