Old 12-03-2011, 01:33 AM
papacraig papacraig is offline
Stinger Owner
Default Milling Spoilboard bit
What bit should I use to mill the spoilboard and where can I get one? I just got a Stinger 1 and I am new to cnc. How do I make a toolpath to do the actual milling? Thanks for the help!
Old 12-03-2011, 03:36 AM
tonywish tonywish is offline
CAMaster Cobra Owner
Mike Mezalick posted this and it helped me:
Here's what I do Tony.
In Aspire I draw a rectangle slightly larger ( + 3/4" ) than the size of my table, the actual cutting area on the CNC machine.
I then have a pocket tool path generated to cut only 1/8" down.
I position my spindle to the lower left corner on the machine ( home) and I move it 1/2" to the left, overhanging the table just a bit.
That becomes the new X0Y0
I use a 1-1/4" planner bit for HD.
Obviously, the larger the bit the quicker you'll be done.
I touch top on the surface and let it run.
You can get pretty fast only taking off 1/8". ( 500 - 700ipm)
Just remember to look for anything that may cause problems with the bit, ( broken off screws, tools left on the table, etc. )
Michael
Michael Mezalick
http://www.mezalick.com
Mick Martin also had some great advice. Do a search on Camheads.
Tony
Old 12-03-2011, 08:57 AM
fixtureman
Guest
Posts: n/a
When I mill my spoil board I only take off .01 of an inch. If the whole suface is not touched then I rezero and rerun the tool path. You don't need to take off much just enough so you the whole board has some material removed. Once that is done the next time you only will need to take off the minimum material and the you can surface many more times without replacing the board.
Old 12-03-2011, 12:36 PM
Could have not said it better fixtureman
www.usroutertools.com
Old 12-03-2011, 12:50 PM
This is a great router bit for marching the spoilerboard here
Old 12-03-2011, 05:38 PM
Michael Mezalick's Avatar
CAMaster Owner, (MOD, KOTR)
I agree with fixtureman but yo'all know me and I REALLY use my spoilboard, hence the reason for the 1/8".
Michael Mezalick
Cobra, WINCNC
3-D Modeling
https://carveddetails.com
mm@mezalick.com
Old 12-03-2011, 08:09 PM
fixtureman
Guest
Posts: n/a
I don't worry about cuts in the spoil board I just want it flat.
Old 12-03-2011, 11:10 PM
Bob Savage Bob Savage is offline
So what if you know there's one or two Broken off screws? I've hit a couple screws in my time and except for the times I outright plowed through steel screw heads I have been surprised at how well the bits have dealt with it.
If I take off .05 at a time will I really waste my bit?
CAMaster Cobra CR-408 X3
http://www.savagewoodworks.com
Old 12-04-2011, 09:52 AM
fixtureman
Guest
Posts: n/a
My spoil board is glued down no screws. In fact if you screw a spoil board down you can get movement.
Old 12-24-2011, 02:32 PM
Since nobody replied i thought i would follow up.
The answer is yes, a busted screw will destroy your bit. Bubye 1.5" mortising bit.
bit, milling, spoilboard
