Old 04-19-2020, 11:30 AM
Michael Vergino Michael Vergino is offline
Default Oval circles
I have noticed that cutting circles ether with profile or pocket the hole or circular cutout are not round they are oval one side is the dia I put in, but other side is about .015 under, Any ideas ? I have been doing cut with a 1/2 dia cutter. Also does not seen to make different where on table and size of circle.
Michael
Stinger 1 with Recoil Lathe
1.7 KW Spindle
Performance Package Pro
Remote Handheld Keypad
SolidWorks 20
VCarve Pro 10
Old 04-19-2020, 01:18 PM
carasel carasel is offline
I am not familiar with the stinger. As a thought. If your top and bottom run along the y. This makes the sides run down the x.
If its always the same side cutting oval. I would look at the gears and rails on that side of your stinger.
what about your hold down? could the bit be pulling or pushing your part?
Try a small diameter bit. Just barley cutting the surface. Does it cut round?
Eddie Kitson
Cobra 5x8 ATC
5hp spindle
20hp regen vac
laser pointer
V carve 9.5
Old 04-19-2020, 03:52 PM
Does it with a v bit cutting .015 deep.
1.7 KW Spindle
SolidWorks 20
VCarve Pro 10
Old 04-19-2020, 07:49 PM
Check your belt tension and make sure that the spring loaded slide plate moves freely. Also check condition of spur gears
Old 04-20-2020, 10:44 AM
Will check that. Thanks
1.7 KW Spindle
SolidWorks 20
VCarve Pro 10
Old 04-20-2020, 06:10 PM
I checked and everything seemed fine I also tweaked resolution. What I found was that if I lowered speed from 100 in/min to 50 the hole was almost perfect. I was using the Vectric default . Are there any recommendation for travel speed ?
1.7 KW Spindle
SolidWorks 20
VCarve Pro 10
Old 04-20-2020, 07:33 PM
Joey Jarrard's Avatar
Joey Jarrard Joey Jarrard is offline
Administrator
you should cut great circles at 100+ ipm. i agree with gary you need to check the belt tension. they should be able to flex no more that 1/8"-3/16" from neutral. if they do then it is too lose. if it doesn't move at all then it is too tight.(yes a belt can be too tight) if all seams ok check your gear rack to see if something is gummed up in the teeth. if this is ok then check the tension spring on the gear box. after that check your bearings. I have seen bearings packed with wood chips or mdf dust make a cnc run like crap.
just my 2 cents
Joey Jarrard
US Router Tools
888-720-TOOL (8665)
www.usroutertools.com
Old 05-22-2020, 11:51 AM
Found the problem ! The pinion gear was loose, now it cuts perfect circles and the the exact dia.
Thanks For help
Mike
1.7 KW Spindle
SolidWorks 20
VCarve Pro 10
