Old 04-15-2021, 01:43 PM
Kurtis Kurtis is offline
Default Aluminum Finish
I received my Cobra earlier this year and its been a crash course for sure. I've started making aluminum parts now. I think its doing ok but I really want to improve the surface finish. I'm using a 1/4 spiral O flute with zn coating. I do not have a mister. My vac does a good job keeping the part free of chips until I cut deep slots. I'm open to suggestions. Thanks
Pass Depth .050"
Step Over 40%
Rpm 21000
Chip Load .0038"
IPM 80
Plung Rate 1 ipm
Old 04-15-2021, 03:38 PM
CodySmith's Avatar
CodySmith CodySmith is offline
CAMaster Sales
I would recommend a smaller stepover, like maybe 10% and that will help with the tool marks. I use a Mister here at the shop as well.
Pass Depth .050"
Step Over 40%
Rpm 21000
Chip Load .0038"
IPM 80
Plung Rate 1 ipm
Cody Smith
Sales Manager
Direct: 678-792-3835
cody@camaster.com
www.camaster.com
Old 04-16-2021, 08:53 AM
kjoiner kjoiner is offline
Leave about .005-.010 material at the bottom and try a finish pass with a smaller stepover as Cody recommends. I don't have a mister either but WD40 works really well for me.
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
CAMaster Stinger 1 23
FTC, Laser Cross Hair
Vectric V Carve Pro
Remote Handheld Keypad
Solid Edge 2021
Old 04-16-2021, 12:54 PM
Bruce Page Bruce Page is offline
You also want to make sure the spindle head is trammed-in as close as possible. Mine needed adjusting after delivery, it was out by several thousandths.
It was not difficult to tram my Stinger, just loosen a few bolts and tap in. I’m not sure how Cobra’s are set up.
Bruce Page
2013 Stinger 1 SR23
Mick Martin Table
Aspire 10, WinCNC
Chips-a-flyin’
brucep128@gmail.com
Old 04-16-2021, 01:01 PM
Do you guys have any pics of your work to share?
Here's a pic of 10% step over that I ran a couple weeks ago.
Old 04-16-2021, 01:06 PM
Last pic was too small
Old 04-20-2021, 04:59 PM
CosmosK CosmosK is offline
The O flutes I have are on the long side. For bottom finishing, short and stubby will do better. Why are you using an O-flute? I would go with 2 or 3, bigger diameter and less rpm. Also, uncoated will be sharper so better finish. If you can't get mist, try to get an air blast pointed at it.
2014 Stinger II (SR-44)
1.7 kW Spindle w/ speed control, Performance kit, VCarve Pro
www.cosmos-industrial.com
>Pen Marking Tools >CNC Drag Knife
Old 04-24-2021, 10:52 AM
asaucier12 asaucier12 is offline
3/8- 2 flute
14k rpm
Last pass doc- .02
Step over 75%
Stinger III SR-48
3 KW Spindle
Laser Cross hair
Maglube Misting System
VCarve Pro V9.5
