Old 10-20-2020, 01:18 PM
kjoiner kjoiner is offline
Default 3D printed tooling for sheet metal bending
I use my Stinger 1 mostly for cutting flat patterns in aluminum for prototyping small sheet metal parts. I've had a vise brake for many years along with a pan brake to form the parts. Frequently, I run into interference where the part hits the die. I found some sites where sheet metal shops are 3D printing tooling for press brakes and they work quite well - even for thicknesses up to 10ga steel. I decided to give it a try and printed a few small dies on my Prusa printer. They work quite well. I'm going to try to attach some photos to illustrate what I did. Two of the tools I created in Solid Edge, and one tool I downloaded and modified (the last one with the .03 radius). Basically, the mods include adding a top ledge to hang on the vise jaw and a pocket where I super glued a magnet so the tool will stick to the jaw.
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
CAMaster Stinger 1 23
Vectric V Carve Pro
Solid Edge 2021
Old 10-21-2020, 07:17 AM
TimPa TimPa is offline
very impressive design and application.
i am dumbfounded that 3d printer material has that type of strength!
Panther PT-404 (aluminum)
6 position ATC w/5hpHSD, Aspire 9.5/WinCNC, Recoil, Laser, Hurricane
near bottom of the learning curve!!
Old 10-21-2020, 08:24 AM
Hi Tim,
I was quite surprised as well and just had to try it. Here is a video that inspired me to try it out. The trick is in the settings used when slicing the part. I added extra perimeters which basically makes a thicker "skin" on the part and also increased the infill to 40%.
https://www.youtube.com/watch?v=wsxF...rt_radio=1&t=0
He does run one of the dies to failure. It was a gooseneck die like the one I made but the forces were higher. Tweaking the settings further would probably resolve that issue.
This video gets into forming sheet metal similar to stamping:
https://shane.engineer/blog/3d-print...et-metal-forms
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
Vectric V Carve Pro
Solid Edge 2021
Old 10-21-2020, 08:25 PM
DVE2000 DVE2000 is offline
Thatís an awesome use model. Iíve had a 3D printer for a couple of months and absolutely love it. I may just get into sheet metal bending.
I actually created a bow sander for printing. Itís really strong, and you can tension the heck out of the sandpaper with it. Itís here, with the Fusion 360 design file: https://www.prusaprinters.org/prints...-with-f3d-file
Gary
Fusion 360
Old 10-28-2020, 08:11 AM
I've seen some very interesting applications for 3D printed injection molding tooling for short runs. It's amazing what you can do with plastic parts. One of the first 3D printed parts I ever did was a carousel type part that was for an automated pill dispenser. Picture something like the old school carousel slide projectors but with 31 compartments(for days of the month). This was back in 2001 and it was done on an FDM machine that cost $50,000. My Prusa printer can probably print better quality and is around $1200.
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
Vectric V Carve Pro
Solid Edge 2021
Old 10-28-2020, 08:13 AM
Gary,
That bow sander is really cool! Thanks for posting the information and the files. I plan to download it and give it a try. By the way, if anyone is interested in the parts for the dies I made, I can try to post them on the forum.
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
Vectric V Carve Pro
Solid Edge 2021
Old 10-28-2020, 08:51 AM
Here are STL files for the dies.
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
Vectric V Carve Pro
Solid Edge 2021
Old 10-29-2020, 11:11 AM
Thanks for the models. Yeah, I love my Prusa MK3S with MMU2S. It's pretty rock solid.
Gary
Fusion 360
Old 02-25-2021, 09:58 AM
JasonK JasonK is offline
Just stumbled on this post while looking for something else. Thanks for sharing it, I’ll have to try this out! I am also frequently bending little tricky things that could work well with this.
I also often bend 1/8” 6061 for one particular part we make and it has to be done carefully in multiple steps since 6061 is so prone to breaking. I can see a printed radius die making this was easier and more repeatable.
Was this done in PLA?
Stinger 3, 3kw, 15hp FPZ blower
Old 02-25-2021, 01:46 PM
Kyle, very informative, thank you for sharing.
Performance Package Pro, Vac, lathe, Aspire 10
