Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > Work we Produce !!!!
Old 11-26-2018, 05:46 PM
Default Projects
One of my colleagues from work has a 2 year old toddler. She'd bought a second-hand race car crib that can convert into a toddler bed. When they converted it into the bed, they she realized that a 27.75" x 12" piece of material was required to cover a gap at the foot of the bed. She has a workshop, and cut a piece of pine. And then thought to ask me if I could use my machine to carve a race track for matchbox cars.
It took all of 10 minutes to design, but then I said I could add some clipart and carve letters and stuff... So we bought some clipart from Design and Make, and I created the recess dishes with Aspire. I also created the raised "1" and "R"
I made some mistakes with the pine, hit some Aspire bugs, and then finally thought, screw it, and glued up some Hard Maple and machined it to depth.
Most of the 3D machining was done with a 1/8" tapered ballnose bit, but the center of the "award" and car grille and centers of the tires were re-machined with a 1/32" tapered ballnose, to really pull out the detail. There were a couple other snafus, but mostly I'm quite pleased with it. She may fill the recesses with epoxy, but she'll use varnish instead of paint with this.
Old 11-26-2018, 06:04 PM
I made an box about 20 years ago for a buddy to store his keys and wallet and stuff. I made wooden hinges with the IncraJig, but I unfortunately used walnut. The hinges broke over the years, and when he mentioned it to me a couple months ago, I had him ship the box to me so I could fix it. It was one of my first projects, and has mistakes galore, but that's woodworking.
I used my machine to cut the old hinges out of the box:
So seeing now I have the capability, I decided to carve my name underneath the bottom of the box. And promptly forgot to measure the tool. So I blew a hole in the box. After saying every four letter word I could think of (and I know a LOT, so it took awhile), I fixed it by created a stepped rectangular shape for an insert. My buddy is originally from Hong Kong and came to the US as a kid. So I carved a tiny Chinese dragon onto the insert.
I made the new hinges out of hard maple. I had to do it the old-fashioned non-CNC way.
It came out ok. The mistakes irritate me. But it is what it is. I wasn't going to make a new one from scratch...
Old 11-26-2018, 08:37 PM
Very nice, Gary. I have been hesitant to use my 1/32 ballnose because of cut times but it sure did pull out the details nicely. Guess Im gonna have to pull up the rocking chair and try it out sometime soon.
drummerjg@icloud.com
Old 11-26-2018, 08:54 PM
That's really nice work and I'm glad to see you're use of the small, 1/32" BN cutter...I'm about to experiment with some smaller tips myself for a few things that need more detail.
Old 11-26-2018, 10:52 PM
Thanks guys. If I recall correctly, the 1/32 machining was just over 30 minutes with the reduced areas.
Old 11-27-2018, 08:13 PM
Originally Posted by DVE2000 View Post
Thanks guys. If I recall correctly, the 1/32” machining was just over 30 minutes with the reduced areas.
Question for you.....did you do an initial pass using a larger, say 1/8 bn and then redo the cut with the 1/32? If so did you set a temp boundary for just the 1/32 bn? Im curious about you procedure.
Old 11-28-2018, 10:26 AM
I did an initial 3D roughing pass with a 1/8" end mill, and then use a 1/16" tapered ball nose (because it's long - model goes about .325" deep) for the 3D finish pass. Then I created a circle around the section with the laurel wreath and "1" for the 1/32" second finish pass. I did it this way because I was hoping the detail of the leaves with the 1/16" bit would be good enough and I could skip the 1/32" bit. I'd cut a test piece in some plywood, which doesn't carve nearly as well.
I'm not sure the initial 3D roughing was strictly necessary, because I used an Offset Pass for the 3D finishes. The machining is from the outside in, which means that the load on the ball-nose bits aren't that high, because I use a 9% stepover.
So by the same token, it probably would have been fine to start with the 1/32" bit from the beginning! I think I saw this mentioned on one of the Vectric videos somewhere.
Old 11-28-2018, 01:13 PM
Thanks, Gary. Im anxious to give the1/32 a try now.
