Old 11-19-2013, 03:57 PM
DonHrehor DonHrehor is offline
Default Router Bit Profiles
Ok ... stupid question and apologies in advance.
I want to add some bits to the Tool Database in Aspire. Looks easy enough to do something like add a Ogee bit, etc etc.
My issue is finding a vector file of the router bit's profile so that I can node edit it. I have asked several bit distributors and one manufacturer for vector files of bit that I would purchase. No go.
Everyone says they do not have them. I have a hard time believing that however that makes no difference in the end I guess.
Does anyone know where I can buy bits and get vector files for them?
Thanks much!
Don Hrehor
Old 11-19-2013, 04:00 PM
trace them.. later I can help you online
Old 11-19-2013, 04:33 PM
Here is an Vectric tutorial http://www.vectric.org/video/aspire4...G14/G14-w.html on how to create a tool
Old 11-19-2013, 06:20 PM
sgodding sgodding is offline
I have a file with most of the profiles from Magnate, if that's helpful. Here it is.
File Type: crv3d MAGNATE Half Router Bit Profiles.crv3d (3.14 MB, 121 views)
Steve Godding
D&S Artistic Woodworking LLC
Old 11-19-2013, 06:31 PM
Default Whiteside profiles
here are all the whiteside (along with many other brands) for the mdf bits (part #s are next to profile)
Old 11-20-2013, 11:05 AM
cdesfablab cdesfablab is offline
James, there are only 7 profiles there, got any more?
It might be nice to compile a single cad file with bit profiles from a bunch of manufacturers with stock #'s. Pretty handy to be able to refer to a single file when making/amending a tool library.
I've attached the Magnate profiles as .dxf in case somebody else can't open the .crv3d
Old 11-20-2013, 11:44 AM
Default Wow!
Thank you everyone for all your responses.
This should get me started and on the right track.
Now I can get all my prep work out of the way while I am waiting on my Stinger 3.
.... and waiting .... and waiting .... and waiting ............
Geez .... the order had been in for 3 days now and its still not here ... hahahahahahahahahahahahahaahahahahhaha
.... Can you tell I have trouble sometimes with patience? hehehee
Thanks again
Don Hrehor
Old 11-20-2013, 12:35 PM
these were provided by whiteside when I was researching MDF doors, most all of the manufacturers provide the full cad dxf for machinist and cnc types. been a while since I was in contact with them,, for most of my needs I just make my own
Old 12-23-2014, 04:03 PM
abesau abesau is offline
CAMaster Logo SE1598 1 1/2" Stair Tread & Bottom Cleaning Bit
Does anyone have the SE1598 1 1/2" Stair Tread & Bottom Cleaning Bit profile for the "Tool Database"? Willing to share?
Old 12-23-2014, 04:28 PM
That is just 1.5" diameter endmill .....
http://www.carbideprocessors.com/sta...t-tool-se1598/
