Old 08-15-2012, 12:15 AM
Default US Router Tools Catalog
Here is a Link to the US Router Tool Catalog.
www.usroutertools.com
Old 08-18-2012, 08:28 AM
rtp_burnsville rtp_burnsville is offline
Has anyone been able to download the catalog??? I have tried on a couple different PC's and it aborts in mid-download.
Robert
Stinger I Router / WinCNC
SprutCAM, V-Carve,ZW3D
Tormach PC1100 / Mach3
Old 08-18-2012, 08:52 AM
JD69 JD69 is offline
Send a message via Skype™ to JD69
No problem for me. I was able to download it and read through it.
Jack
Jack Davis
Stinger I - 1.0kw HSD Spindle
MACH3 - Vectric Software
Old 08-18-2012, 11:53 AM
I also had no problem with downloading the catalog
Old 08-18-2012, 04:55 PM
Thanks guys.... Just updated the Adobe Reader and tried again but still no luck.... Wonder what the deal is with that.. :(
Robert
Old 08-18-2012, 07:07 PM
Default Experimenting
Robert,
If you are clicking on it and having trouble try this. Instead of left clicking to open use the right mouse button and save the file to some location like your desktop. Many times when I have trouble opening directly from a link I try the "Save As" or "Save Target As" and that seems to work.
Old 08-18-2012, 07:46 PM
Hi Charlie,
Tried both and still no success....... What's strange is that the file downloads to about 50% then aborts. As expected if you then try to open what did download Adobe reports damaged file, duh!!!
Old 08-18-2012, 10:22 PM
Default Another idea
Robert,
I really have no idea what the problem is. From your information almost sounds like it is a problem in the feed to the house, like the router/modem. Maybe reboot everything and see if it changes anything. Delete as many Internet files as you can, reset, delete cookies, etc. The fact that it doesn't work on more than one computer got me thinking this way.
Old 08-19-2012, 08:20 AM
Charlie,
I tried the networks at work, home, and two wi-fi connections as well as different browsers. As for PC's, 6 different ones in total which makes this just so strange as others can download it. Guess the black cloud continues to follow me when it comes to PC's.
The only common link is that all PC's were running XP.
Robert
Old 08-19-2012, 03:50 PM
richf richf is offline
This kind of problem is usually related to the network which is also the common element among all your systems. Like Charlie said, make sure to power cycle your wired/wireless router and the cable/DSL box. If this doesn't work, then try switching cables around on your router. If that doesn't work, open a ticket with your cable provider and report the issue.
Your provider may provide you an online tool for checking or they can run a check. If it is a cable system, it could be connectors running from outside the house. I had problems a few years ago and it was basically non-spec cable connector outside the house that was deteriorating. I think I was the one that spliced it together way back when but they fixed it for me for free anyhow.
Rich F.
PrecisionSignandPost.com
BobCAD v25 4th Axis
Corel Draw X5
