Old 06-30-2018, 02:06 PM
Erik Land Erik Land is offline
Jim it might not have anything to do with the collet, but the retaining nut it snaps into. Iíve had nuts with the center hole bored out 10 thousands larger and the collet snaps in fine but dosent hold the bit well befor tightening.
Erik
Erik Land
Dorena Oregon
Cnccutter@gmail.com
Stinger I SR24 11/27/17
Performance package Pro:
2" Gantry Lift
FTC Fast Tool Change
Laser Cross Hair
Counter Balance
Tee Track Table
Kent Dust Shoe
Aspire 9.5
Rhino
Old 06-30-2018, 08:42 PM
I thought of that, too, Erik...two different nuts from two different manufacturers. Same deal. Very weird! But based on previous comments, apparently it happens. At least there's zero issue once the nut is tightened. Whew!
Old 07-03-2018, 11:53 AM
CosmosK CosmosK is offline
maritool for collet and nuts.. great stuff
2014 Stinger II (SR-44)
www.cosmos-industrial.com
>Pen Marking Tools
Old 07-04-2018, 07:04 AM
tmouse tmouse is offline
Did you check to see if your bit is the size it says it is. I have some 1/4 inch bits that measure .24 at the shank
Old 07-04-2018, 10:06 AM
Yes...as mentioned, I've also tested this with like a dozen different cutters, both CNC oriented and "regular" router bits and both premium and "value priced" versions. All of them to a tee are "loose". And this is with both the original 1/2" collet that came with the CNC and the Amana collet I bought as backup.
It is what it is...and again, they tighten up snug and secure for actual cutting. It just takes "three hands" to do that. LOL
