Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Tips & Techniques > Router Bits
Old 08-18-2019, 10:58 PM
Porter Cabs Porter Cabs is offline
Default 5mm boring speed and feed
Anybody have recommendations as far as boring 5mm holes in 3/4" ply.
spindle rpm and plunge rate. Is peck drilling necessary?
I do not have a drilling block. Single 5HP HSD spindle
Thanks for any info
Kyle
Old 08-19-2019, 07:28 AM
Doug S Doug S is offline
First, I use a 5mm brad point bit for drilling so you don't get any heat or chipping. I run one pass, no pecking at 150 IPM plunge rate. I think I am running 12,000 of the spindle but I can verify that tonight.
Sure wish I had a 5 head boring block.
Existing:-2014 Cobra 5x10 ATC w/ 10 hp spindle, Mozaik, 25 hp Becker High Vacuum Pump, 5 HP Oneida DC-Central Texas
New:-2014 Cobra 5x12 ATC w/ 10 hp spindle, pop up pins, phenolic top, lathe, vacuum relief valve, mister system, 25 HP Blower.
Old 08-19-2019, 09:11 AM
Ger21 Ger21 is offline
If you did, you'd wish you had a 12 spindle block.
I have a 12, and wish I had an 18 or 24.
Gerry
JointCAM - CNC Dovetails & Box Joints
Old 08-19-2019, 10:24 AM
Sounds like a group but is in order.
