Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > Photos of CAMaster machines
Old 10-25-2017, 05:34 PM
Default Wife got a vinyl/fabric cutter
So the wife does quilting and needed a fabric cutter. Low and behold the cutter also does vinyl, so while she was gone here's what I did. I used vcarve pro and exported my lettering as a SVG file, this was way to easy. Instant gratification is always good since it took a total of about 15 minutes to do (as opposed to my 4 day epoxy pours).
Bob Walters
Lebanon, Ohio
2016 Stinger II SR-44
3.0 kW Spindle
Vectric VCarve Pro 10.xx
www.cool-signs.com
Old 10-25-2017, 09:36 PM
Obxwoody Obxwoody is offline
Looks much easy than a 4 day epoxy on gantry!!
Old 10-26-2017, 10:23 AM
KickIt KickIt is offline
It looks great. What did she buy, what does it do?
Kevin Stoops
Cobra's 508 ATC
Recoil, vacuum hold down.
Aspire 9, Photo w/Cut-3d, CPP
30W Fiber Laser
TDS Control Keypads - Inventor of the TDS/KRS Keypads
www.krscorporation.com for keypad support home
YouTube Videos
Old 10-26-2017, 12:47 PM
Itís a Brother Scan and Cut 2, just a little hobby machine. She uses it to cut designs in fabric for quilts. Itís a neat little machine. Sooo the crazy in me is now looking for a big machine for me now. The Graphtec CE6000 Plus looks pretty awesome and not to terribly priced.
Bob Walters
Lebanon, Ohio
3.0 kW Spindle
www.cool-signs.com
Old 10-26-2017, 01:07 PM
Gee, thanks, Bob.....the wife saw this and now guess what she wants for her sewing/quilting room!
Storm Vacuum
drummerjg@icloud.com
Old 12-21-2017, 08:38 AM
R.L.Schulz R.L.Schulz is offline
That's cool!
I have been using the Cricut Expressions machines and Sure Cuts Alot 2 Software for years. It makes cutting vinyl and other materials used for lettering, stencils and masking's a breeze!
I never thought about using the Vectric software to create svg files, that's Awesome.
Thanks Mrs. Walters
(and you Bob)
Ron & Tammy Schulz
CAMaster Stinger III SR-48
X3 + 2" Gantry Lift + Extended Gantry
HSD 3.0 KW + Counter Balance
Laser Pointer + Tool Measure Switch
Indexing Recoil Lathe
Hurricane Vacuum System
Vectric Aspire 9/9.5
Cabinet Planner
Old 12-21-2017, 08:54 AM
Been wanting a small one for a while, thanks for the encouragement, as well to all when photoing work or machine we always made sure the logo on the gantrys were in the photo. made the best advertising to all !
fixed 4-27-2020
Old 12-21-2017, 10:10 AM
Well, there's been an update. I now own a Graphtec CE6000 plus vinyl cutter. It does the job way faster and even easier when using the Vcarve program. I'm going to experiment with using the Camaster with the vinyl cutter after the holidays. Thinking of easy "bar top" type of table with a clear epoxy over the vinyl to see what it looks like compared to my full epoxy inlay. Would save me several days if it looks as good (the satisfaction wouldn't be there unfortunately that I get with the epoxy).
Bob Walters
Lebanon, Ohio
3.0 kW Spindle
www.cool-signs.com
Old 12-31-2018, 03:14 PM
Ron Hampe Ron Hampe is offline
Go all the way and buy one of the 3d vinyl printer/cutters! Those are pricey, but sweet!
Stinger III - SR48
3.5hp Milwaukee
Pro Package
T-Slot Table
Hurricane Vacuum
V-Carve Pro
Old 12-31-2018, 07:10 PM
Congrats Bob. I've been looking at one of those for a while, never pulled the trigger as I've been swamped with other stuff. Is it pretty easy to setup and run and does it appear well built? Where did you order it from? Us cutter?
Wes
Steel 5X10 Panther
VcarvePro 9.5
