Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > New Forum Members
Old 04-26-2019, 06:19 PM
A Isbell A Isbell is offline
Has anyone used the engraving laser?
Old 04-26-2019, 08:40 PM
I don't know that any machines have shipped with it yet...it's a brand new option. Luke posted about it in his personally "locker room" area here in the forum just a short time ago.
Old 04-26-2019, 08:53 PM
Logan Y Logan Y is offline
You'll have to let us know how it is.
4'x8' Stinger IV w/ 4.2 hp spindle and 4 tool ATC
Mister system
Phenolic Vac table
Hurricane Vac
Vcarve Pro 10
Catholic school IT director, wannabe woodworker, Krav Maga instructor, and CNC enthusiast
Old 04-26-2019, 09:17 PM
I believe this member has one on his machine , here is the link to a thread he posted .
https://www.camheads.org/showthread....t=laserhttp://
Herb Holmes
Performance Pkg
Slotted table
WINCNC
Aspire 8.505
Porter Cable 2.25
CAMaster Stand
Old 04-27-2019, 09:32 AM
I had forgot about that, Herb...thanks for linking to it.
I suspect that "setting expectations" realistically for the gantry mounted laser is going to be very important for folks opting for that option. It's not a replacement for a dedicated laser system but will certainly enhance the capability of the CNC router format. I suggest folks opting for the laser carefully consider shop ventilation, too...
Old 04-27-2019, 03:34 PM
Hope to get my machine in a couple of weeks should can't wait to try it out!
I have used Model Master CNC to carve waxes to make jewelry with Artcam Jewelsmith for about 20 years. Now I use a 3d printer to design the jewelry with artcam and Matrix (a Rhino Program) Hopefully the learning curve want be to difficult.
Old 05-01-2019, 10:43 AM
do you offer online training?
Old 05-17-2019, 02:02 PM
Default Spoilboard cutter
What would be the best spoilboard cutter to order? want to flatten slabs with it also. 4 inch straight insert or up? 2 or 3 cutters? is 4 inch too big for stinger III with 4.02hp high frequency spindle from HSD?
Anthony Isbell
Old 05-17-2019, 04:15 PM
Insert for sure. I don't know that I'd swing a 4" cutter on your machine, however. I'd go half that so it's easier on the machine and honestly, even then, it doesn't take a ton of time to clean the surface. I use a 1.25" insert cutter on my Stinger II and it's also been versatile for other things, like surfacing solid stock and "large-large area" clearance removal on a door panel awhile back.
