Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Software > FUSION 360
Old 06-08-2019, 10:20 AM
Dan Schmidt Dan Schmidt is offline
Default Fusion360 Post for 4th Axis
Anyone aware of or using a Fusion360 post for the recoil?
Dan
Dan Schmidt
  • PT404 Panther w/ 3kW spindle
  • Cyclone Vacuum System
  • Indexing Lathe
  • FTC/Laser/Assist/Remote
  • Fusion 360 / Vectric V-Carve Pro
Old 06-10-2019, 09:36 AM
I spent quite a bit of time looking at tool paths for lathes in Fusion360. This was before I received my machine. I finally came to the conclusion that it wants to treat rotary jobs as regular CNC lathe jobs. With cutting tools, and not router bits. I finally gave up and decided to just make sure to get Vectric software with my machine. I'm glad I did.
To totally change the topic, I upgraded to Aspire, but on my rotary test cuts with a couple of 2x4's, the software definitely distorts clipart when wrapping. When I have time again, I'm cutting the clipart either as a flat job over the rotary (or on the table). With manually rotating the A axis for each surface.
Old 06-11-2019, 04:24 PM
Good points; I agree. It seems Fusion360 wants only to recognize a lathe, and Vectric (despite 9.5 rotary improvements) is still native flat surface with post processor wrapping. Hopefully both software programs mature 4th axis routing.
Dan Schmidt
  • Indexing Lathe
Old 06-11-2019, 06:17 PM
Dan...
I am a frequent contributor to the Centroid CNC Forum and those that have lathes say that Fusion 360 leaves a good bit to be desired. Not so much in the design end, but in the toolpath output.
