Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Tips & Techniques > Router Bits
Old 04-23-2017, 04:51 AM
Mick Martin's Avatar
Mick Martin Mick Martin is offline
CAMaster Cobra Owner (MOD, KOTR)
Post US Router Tools Feed and Speed Chart
I have attached a US Router Tools feed and speed program, download the ZIP file then extract the program. To find your feed rate for a tool is enter you RPM into the green box then click "Calculate Feed Rate"
Mick Martin
mickmartin3@comcast.net
CAMaster Cobra 508 ATC + Recoil + Popup Pins
Digitize Touch Probe
Wincnc Handheld Serial Keypad + Wireless Pendant
Hurricane vacuum
WinCNC + Aspire 9.5 + PhotoVCarve + EnRoute 5
www.customarchitecturalsignage.com
www.mickmartinwoodworking.com/
The search function on the forum is your best friend!
Old 05-05-2017, 08:08 PM
Joey Jarrard's Avatar
Joey Jarrard Joey Jarrard is offline
Administrator
it has a little more work but the chip load calculator is also available on iphone and android.
001 - what the icon looks like
002 - the splash screen
003 - start at the top and select the type off material you are cutting
004 - the drop down has a good selection of the most used substrates
005 - select how many flutes your bit has
006 - type in your desired RPM for most wood I cut at 16,000 RPM
007 - look on the list for the diameter of your tool and you have your feed rate**
** if your using a router or less than 5hp spindle you need to stay on the low end of the range. If you are cutting with a large spindle and high quality tools or dimond tooling you need the high range
I hope this helps, i need to have the guy do some work on the graphics and a link but for now it works
Joey Jarrard
US Router Tools
888-720-TOOL (8665)
www.usroutertools.com
Old 05-08-2017, 12:35 AM
Joey,
Where can you find the app
Mick Martin
Hurricane vacuum
Old 05-08-2017, 06:48 AM
For the Android it is titled, CNC chip load calculator. I found it by searching for chip load.
Old 05-08-2017, 09:22 AM
Thanks Charlie,
For the IPhone its also called CNC chip load calculator
Mick Martin
Hurricane vacuum
Old 05-08-2017, 11:37 AM
Joe Travis Joe Travis is offline
Thumbs up
Been using Joey's app for months and it works great. Easiest way I've found to dial in feeds and speeds.
Joe Travis
Sawdust Designs
2015 Stinger II SR-44
Recoil
Pro Performance pkg.
HSD 2.8 KW Spindle with Quick tool change
T-track table
Aspire V8 , WinCNC
Woodworkingnd@live.com
Old 05-08-2017, 12:02 PM
Administrator
@ Mick i guess it would of be better to tell folks they could get it on the app store. lol thanks
@ Joe thanks joe i use it my self as well. when i have time to get with my guy, we will add a few things but the most important thing is the math in there.
Joey Jarrard
US Router Tools
888-720-TOOL (8665)
Old 08-23-2018, 04:03 PM
It seems the app is no longer available on the IOS store?
Old 08-23-2018, 05:35 PM
Their website has been really wonky, too...
Old 10-24-2018, 07:45 PM
1601chief 1601chief is offline
Question on speeds and feeds . what depth do you do?
Andrew Pierce
Aspire 9.5
Wincnc
2 1/4 hp router
Performance Pkg Basic
Digitizing Probe
KRS Keypad
