Old 10-29-2018, 08:12 PM
What are they calling a transmission? That shaft with the pulley and gear?
Old 10-30-2018, 07:54 AM
Doug S Doug S is offline
I sent in the entire motor, belt and pulley assembly and slide plate. The 10:1 reduction has bearings which wear out and the slide plate needs to be maintained also to keep it moving freely.
2014 Cobra 5x10 ATC w/ 10 hp spindle, Mozaik, 25 hp Becker High Vacuum Pump, 5 HP Oneida DC-Central Texas
Old 10-30-2018, 08:28 AM
John B John B is offline
Not a long term fix, but more of a diagnostic effort here...
Remove the suspect set screw. Pack hole partially with a piece of "pulled off" bronze wool. Replace screw and tighten hard.
Any improvement will likely be "short lasting", but shouldn't harm anything and will at least confirm that this is where the problem lies.
If tech support gave you the torque specs on that screw, use them.
Also...you can sometimes tell what the "exploded" view of the assembly would tell you by examining the set screw. If it is a set screw that's in...say...an aluminum pulley that's riding on a steel shaft, then a flat bottom screw would likely indicate that it bears against a flat spot on the shaft. If it's "pointy" or dimpled, then it could be either a "flatted" or round shaft. You might also try replacing just the set screw(s). These are "somewhat" sacrificial. If it's been tightened too hard and the tip has been crushed against the shaft, then replacement will give you a new surface to bear against the shaft.
Old 11-01-2018, 05:33 AM
Tristan Tristan is offline
Send a message via Skype™ to Tristan
I have had the same issue, basically the shaft on the pulley/pinion was worn out, and the bearings that the shaft runs on was not too happy. Unfortunately, the shaft does not have a keyway (mine at least does not), so I machined a new shaft with a keyway, replaced replaced the bearings and "Bob's your Uncle"... The Pinions, I do need to replace every now and then. The smallest play in that shaft, makes a BIG difference in the accuracy of your machine.
Tristan Brammer
CAMaster Cobra CR-609 ATC
2018 CAMaster Elite CR-609 ATC
WINCNC
Enroute 4 and Aspire v8 Design Software
AutoCAD, Autosketch, Sketchup
Razor CNC
Aspire v8
"Sawdust means Work in Progress"
Old 11-01-2018, 08:21 AM
Originally Posted by Bert Wilson View Post
Posted this problem last Friday and sent link to Camaster. Post was removed, and historical link was password protected. Reposted this AM and re-sent link to Camaster already.
We use this machine every hour of everyday in production. When it stops working I need answers or parts immediately. Waiting is not something most businesses can afford.
Bert as the Admin, i Would see all post, I get everyone everyday on my phone and computer, i look at every one, I can find no log of any post removed that you have written,
Old 11-05-2018, 03:15 PM
Bert Wilson Bert Wilson is offline
CAMaster Cobra Owner
Here are screen grabs of the post link data and message:
Bert
Bert Wilson
H. Gerstner & Sons Inc.
bert@GerstnerUSA.com
CR-510 Cobra HSD 5hp w/ATC
V-VC202 (21) Elmo Rietschle Vacuum Pump
WinCNC + Vcarve Pro
www.GerstnerUSA.com
