Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Software > FUSION 360
Old 04-28-2019, 07:37 PM
Dan Schmidt Dan Schmidt is offline
Default WINCNC Errors
I'm having lots of trouble with the Fusion360 WINCNC post. I am using wincnc_atc.cps from http://wincnc.net/webfiles/Post%20Pr...DeskFusion360/.
Below is a short GCode file with a simple drill operation and a 2D pocket. When I try to open the file in WINCNC, I get "Error - Multiple Commands". Can you tell me what looks off? Any tips on how to debug a gcode file when it fails loading into WINCNC?
[1001]
[DP Tray]
[T3 D=0.375 CR=0. - ZMIN=0.1575 - flat end mill]
G90
G20
G53
[2D Pocket4]
T3
S18000
M3
G0 X1.2318 Y3.7756
Z1.3386
Z0.9449
G1 Z0.8465 F130
Z0.1575 F65
G3 X1.2968 Y3.7106 I0.065 J0. F130
Y3.8406 I0. J0.065
X1.2318 Y3.7756 I0. J-0.065
G1 Z0.195
G0 Z1.3386
X2.2187
Z0.9449
G1 Z0.8465 F130
Z0.1575 F65
G3 X2.2837 Y3.7106 I0.065 J0. F130
Y3.8406 I0. J0.065
X2.2187 Y3.7756 I0. J-0.065
G1 Z0.195
G0 Z1.3386
X3.2682
Z0.9449
G1 Z0.8465 F130
Z0.1575 F65
G3 X3.3332 Y3.7106 I0.065 J0. F130
Y3.8406 I0. J0.065
X3.2682 Y3.7756 I0. J-0.065
G1 Z0.195
G0 Z1.3386
M5
G53
Dan Schmidt
  • PT404 Panther w/ 3kW spindle
  • Cyclone Vacuum System
  • Indexing Lathe
  • FTC/Laser/Assist/Remote
  • Fusion 360 / Vectric V-Carve Pro
Old 04-28-2019, 08:25 PM
Ken Rychlik Ken Rychlik is offline
The G3 move is an arc requiring x y and radius info.
The line below it is just a Y with a radius. To me that doesn't look good. You can't have an arc move with just one axis moving.
After is does any type of move like a G1 move command, any command below that without calling a different type of move is going to be considered a G1
So with the move after the g3 arc move, it is confusing.
I would delete the line after the G3 moves and see if it loads. Not to run the file, but to see if that's it.
Fixing machines and making sawdust.
SW side of Houston
Old 04-28-2019, 08:39 PM
I experimented and found that the simulation in WinCNC didn't like having the G3 commands, without the G3 in front of the x y I commands. Just like Ken explained. Maybe adding a G3 works?
Old 04-28-2019, 09:15 PM
Add the line: "g2modal=1" (without quotes) to the WinCNC.ini file and see if that works
If you have input parameters in Fusion 360, you maybe able to check, or enable G2/G3 modal/nonmodal or force the G2/3 commands to be placed on every applicable line
Old 05-01-2019, 10:59 PM
Thanks to each of you for your replies.
Ken, deleting the lines after the G3 moves resulted in "Error - Radius" when loading the file.
Charlie, when I added G3 in front of the lines as you suggested WORKED!
Gary, I was concerned that I'd have to learn and modify the post. The g2modal=1 setting worked perfectly!
You guys are awesome!!!! Thank you!
Dan
Dan Schmidt
  • Indexing Lathe
