Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Tips & Techniques > Materials we Need !!
Old 08-22-2020, 09:28 PM
In my shop if I wanted 30 Degrees V for colorcore, I would try my Onsrud 37-25 which has a 0.020 inch flat.
I have my machine running, maybe I'll try a sample?
Old 08-22-2020, 10:01 PM
Experiment done....
Font used Calibri having bold selected. I wasn't sure what you had used but maybe this was close enough?
Text height was 0.25 inches, the word "Adventure" was 1.65 inches long for reference.
I typically add 0.030 for start depth when using color core, because the colored skin is 0.050 on my 1/2 inch material. I did that here.
In the photo the word "Trident" used the 30 degree tool listed previously. That didn't look very good so I stopped and used my 60 deg Onsrud 37-07 for the last three words. It has a 0.030 flat tip. MUCH better results. Still deep enough I think. The picture is taken immediately after cutting. No cleanup other than vacuum running.
Aspire toolpath says the maximum cutting depth was 0.058 thousandths. It looks a little deeper given the amount of white showing. That is for the 60 degree. The 30 degree is deeper, but lots of debris still standing.
Old 08-22-2020, 10:10 PM
ArlingtonM2 ArlingtonM2 is offline
Originally Posted by Charlie_L View Post
Experiment done....
Charlie, Thanks so very much for running that test so quickly! How very kind of you.
That's interesting that the 60 deg bit had fewer fuzzies. I should have tried that myself. I don't have any with a flat tip. In fact I didn't even know that they existed. Will have to look for those.
Super great info and again, thanks much!!
Ken
Stinger I (2014) with FTC, 1.7kw Spindle, Recoil Lathe
Learning (and re-learning) every day
Old 08-23-2020, 09:30 AM
Given the depth of the 30 deg cut, another thing I should have tried was to put a bottom to the text using that bit. That would have made a cleaner cut too.
Old 08-25-2020, 08:04 PM
JeffP JeffP is offline
Late to the party here- Centurion Tools makes engraving bits specifically for ColorCore.
https://www.centuriontools.com/collections/engraving
Jeff Potts
Cobra 508 ATC
VCarve Pro
