Go Back   CAMheads CNC Router Forum By: CAMaster CNC > New CNC Setup. > General Discussion
Old 10-22-2019, 06:52 PM
Bruce Bruce is offline
Default Using the laser on a Panther
Are there particular settings I should be aware of on the Vcarve program in order to use the laser engraver?...or if there is a Camaster info page on laser set up and use that I could be guided to as I've not found much on how to actually use the laser... I'm a newbie and just trying to get a feel for the laser part of the machine... Thanks!
Bruce Jeansonne
decorativecabinets@comcast.net
CAMaster Panther 508
Laser Engraver
Hurricane Vacuum
WinCNC and VCarve Pro
https://www.facebook.com/decorativecabinets/
Old 10-25-2019, 10:23 PM
I think you need Gary C for this one.
Found a video. aslo check vectric forums.
https://youtu.be/9q5M8dMgR44
