Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > Questions For The Sales Team!
Old 03-03-2020, 09:24 PM
MARSIMI MARSIMI is offline
Default Shipping container size
Hey folks i just ordered a stinger II with recoil prep and did not ask how large the shipping container is - can you give me some rough dimensions that i can work with in terms of delivery as I was thinking for getting a hydraulic drop trailer to bring it home - just not sure how wide it would need to be.
I have been wearing grant out with questions so thought i would ask this one here
Thanks in advance
Old 03-04-2020, 12:19 AM
NEWorkshop NEWorkshop is offline
My Stinger II just arrived today. The crate is 8ft long and 7ft wide.
Old 03-04-2020, 07:08 AM
Use a car flatbed wrecker. They can tilt to unload. Slides right down the bed with a little dish soap.
https://camheads.org/showthread.php?t=2028
Old 03-04-2020, 07:12 AM
Default Thanks
Thank you both!!
I was thinking of a hydraulic trailer but not sure of the distance between the wheel wells so will find out. If that is not going to work i will need to find a wrecker
Old 03-04-2020, 07:14 AM
Default Stinger II
Did you have the recoil or the recoil prep added ?
Old 03-04-2020, 09:31 AM
No but there's plenty of room around it so they likely use the same size crate. Anything bigger wouldn't for into a regular semi truck box.
I'm just uncrated mine now.
Also found that most trailers we measured were only like 1" under 7ft between the wheel wells... Had to do this.
Old 03-04-2020, 09:57 AM
Default receiving
Thanks - i dont have a skidloader of any type. But i think my idea of the trailer wont work at that wide. I need to see what i can rent. Perhaps i just need a trailer and loader. I think the machine with the crating is under 2k lbs so should be doable. Or get a tow company to slide it off
Old 06-08-2020, 10:34 PM
jj02086 jj02086 is offline
Default Sr-44 with recoil
I just uncrated mine on Friday last week. The crate was 8ft x 10ft with a recoil added. As far as weight. I have a tractor with forklift that is rated for 2000lbs and it wouldn’t pick it up. It’s a good thing that the trucking company put it on a tilt bed trailer for me.
Jimmy J
Stinger II, X3, 3kw, Recoil, FTC,
Laser Engraver & pointer.
VCarve Pro 10
