Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Software > FUSION 360
Old 10-15-2018, 06:33 PM
browndawg browndawg is offline
Default Fusion 360 Post Processor
Greetings: Is anyone using the latest pp for wincnc? Is it working to your satisfaction? Any users out there what to collaborate on working on some thing that works? There has been a few posts on this. This forum is a great tool.
Any one interested please chime in.
Old 10-16-2018, 10:40 AM
krossdal krossdal is offline
Hi browndawg
I've been using a PP that I found on this forum about a 1-1/2 year ago. I've modified it so I can use the 4th axis and also added some properties to it to be able to use two length offsets etc.
I use Fusion 360 every day in my business. Right now I'm trying to figure out how to get the PP to work for the Flow toolpath. I'm getting wrong Z and A values at the moment.
It's more than welcome to share that PP if you're interested.
Kristjan Krossdal
Iceland
Stinger III - 2017
Options and upgrades:
3.0KW HSD spindle, FTC, Laser Cross Hair, Counter Balance, Digitizing Probe, Remote Handheld Keypad, Indexing Lathe and a 6" gantry overtravel.
Software:
Vectric VCarve and Fusion 360.
kristjan@krossdal.is
www.krossdal.com
Old 11-30-2018, 01:58 PM
Well, actually, yes.
I just took a closer look at Fusion360 since Sketchup is not meeting some of my requirements (notably, CNC integration). I'm curious about the present state of the Fusion460 PP for CAMaster and am willing, perhaps able, to help move that task forward if that's needed.
Looks like we might be neighbors too as I'm also in western Mass.
Mike Davison www.DavisonWoodworks.com
Stinger II with Recoil, GCNC Sidewinder Lathe, Aspire, Sketchup
Old 11-30-2018, 02:49 PM
DVE2000 DVE2000 is offline
I've been meaning to try Kristjan's post, but haven't got around to it. It's easy enough for me to design something in Fusion360, use the free Shaper Utilities Add-In found at Autodesk, export SVGs, import them into Aspire, and resize them. While I spent a lot of time playing with the Fusion 360 CAM before learning Aspire, it's a bit easier to create tool paths in Aspire, and the simulation output is awesome. And I've modified the Vectric posts a bit for FTC. I actually get to see the tool description and tool path name at the tool change pause. (Posted in a thread somewhere here.)
If you have Vcarve and would like to export from Sketchup to VCarve without any hassle, you can sign up for the Fabber beta at https://www.getfabber.com. I played with it a bit, and while it's beta, it works really well.
Gary
Fusion 360
Old 11-30-2018, 03:23 PM
Originally Posted by krossdal View Post
Hi browndawg
I'd like to fiddle a bit with Fusion360 and this PP. Thanks for sharing!
Old 11-30-2018, 03:25 PM
Well, I guess we're veered off from Fusion360, but what does Fabber support? the web site is totally content free.
Old 11-30-2018, 03:57 PM
Yeah, you get Dropbox and forum links once they sign you up, but pretty much there's a Vectric Gadget and a Ruby installer for Sketchup. You take a Sketchup design - as is and assembled - and you run the Sketchup plugin, or whatever they call it. You then run the Gadget in Vcarve/Aspire and it lays out the pieces flat as vectors for you. You'll have to use the vectors to create toolpaths yourself.
Gary
Fusion 360
Old 11-18-2020, 07:25 PM
nhfoley nhfoley is offline
Resurrecting this thread as I am now trying to get set up with Fusion 360 as my machining solution. With some tweaking, I'm successfully (so far) using the WinCNC post processor managed by Autodesk, though I'm having to delete some apparently spurious G43 commands manually in each file. Anyone else have this fully functional? Or other post-processors they are set up with?
Old 11-21-2020, 11:32 AM
I think I've got this figured out, including Recoil support. Will post the files here for others once I get a little more testing in. DM me if you are interested in testing it out with your workflows.
Old 12-02-2020, 02:37 PM
Going to post the latest rev of my F360 CAMaster post processor with Recoil support in case anyone else needs it. Have been successfully using it to make 4 axis parts without much limitation. Will post updates as I uncover any further bugs.
